Header swivel arm for 1091 Hesston
dmiller
Anyone know if the center connecting link (the one with the swivel ball on the floating head) between the main swather frame and the floating head on a 1091 Hesston can be replaced/purchased?
Have tried to search for the part online and haven't had much success.
What I found when I looked it up, I think I'm in the right place, is part number 6581797. Have to replace the entire lift tube mechanism. Must be welded together (if I remember right it is welded to the tube). Any other fix would probably have to be a shop cut and weld affair to replace just the ball part. Thought I had a parts book for the 1091 but didn't so looked on Agcoparts.com to find it.(I guess it was the old PT-10 we had parts book for.)
Do you need the ball and such or the whole thing? Like said below believe its welded to the tube that lifts. You'll probably have to have something fabbed up. Mine has a patz gutter cleaner link where the ball used to be.
