JD 435 Baler
69stang
I purchased a 435 round baler last year, and it worked well except for the net wrap rollers would not pull the netting through. According to my manual the adjustment is correct for the roller. I don't know if I should tighten up the rollers, or if there is another problem.
Besides double checking surface wrap roller spacing I'd advise to check condition of surface wrap belt & condition of sheaves that belt fits around.
CC30453 V-Belt - V-Belt ADD 19.54 USD
Another thing to check is the clearance on surface wrap gate guide(parts key 5). If guide is too far from belts in gate surface wrap won't feed down between belts & guide
Oh how I miss the edit function on Modern view!
Also make sure this guide is rust free too. Rust will make the mesh wrap not feed correctly. The top of this guide needs to be smooth. Any rust or nicks will make the mesh not feed right.
