Read several posts on making sure the slip clutch is adjusted on a Deere square baler.
High on the to-do list on my 348 is to make sure the slip clutch is adjusted and definitely not rusted/stuck before we begin baling.
The manual says, "Check clutch slippage using a spring gauge and 10ft lever attached to power shaft. Exert force at 90 degree angle."
Understand the 10ft lever as doubt anyone has a short handled torque wrench to handle the 550 (for cat 4 driveline) ft lbs torque or 600 (for cat 5 driveline) ft lb torque setting.
Are you setting your torque as per the JD manual and what are you hooking the lever to - how are you grasping the front of the PTO input to the slip clutch? Are you removing the PTO shaft and holding the spline input shaft on the slip clutch? I assume the slip clutch is similar on all JD square balers from the 336 to the present?
Like to get this 348 off to a good start and I think the slip clutch check/adjustment is high on my list.
Thanks!
Bill
Thanks!
Bill
