JAsher452x
this weekend i picked up a Minnesota spreader. I did some research before hand because i could not find markings and such on it. its is functional, chains in good shape but needs a little work, new wooden chain tensioners, missing covers. the biggest thing is one of the shaft seals is leaking on the gear box. the PO would add a quart of oil before use every time. Oil leaks on anything drive me nuts. Does anyone have a parts break down for the gear box on these. if no avail i have seen a manual on fleabay. worst case i will have to take the gear box off and get some measurements and find a seal that will fit
