Please help ID this pond scoop. Thanks, John
I looked around a little, did not see another one like it,
I have a ford model, works great,
Have you used it yet?
I am a bit concerned at where the frame hinges on the scoop, it appears you fill that scoop with dirt, gravel and it's not going to want to dump,
My ford is hinged close to the center of the bucket,
No matter what you think of the ford brand, one thing they did do is make a fine pond scoop, I should know I have owned 3 or4 different brands of scoops over the years,
Well it looks as if I have the rarest pond scoop ever made. Not one person on two great tractor websites has been able to identify it or give any direction.
I have seen a lot of old crusty equipment identified in moments here.
Wellmax no I have not used it, just got the tractor TO30 and 5 implements from my grandfathers estate.
The look also concerned me. I thought it would dump just fine with the hinge location. What I did not get is after it dumps being hinged like it is how would you relatch it? It looks as if you would have to put it on the ground each time to relatch it. Thoughts? Thanks, John
They need weight to make then dump and without the weight they come back up to the carry position. Perhaps a few more pictures from different views including the complete unit without any shaddows someone might be able to identify it.
