parts getter
I used to do that for people with busy lives. Used to charge 10% of the cost.
I gave it up last year. I did pretty good but it was very time consuming on my end.
Have found everything from air plane parts, tractor parts and boat supplies.
Delta--I haven't had any luck on the implement forum yet. I have posted some pictures and names of parts. I know that somewhere in this big old country there is an abandoned parts warehouse with a bunch of bearings and bushings for my bog harrow. Either that or an implement yard with one to take apart. Ellis
Hi Ellis
If you give me a list of the part numbers, I will see what I can find.
E-mail is open at bottom right (Classic view)
Wayne
Ellis, call Shoup parts or Ag Supply Co. I've had wonderful help on finding parts that I've needed talking to the girls from both companies. They do know what parts fit what well. And the girl from ASC saved me a bundle on some bearings and stuff I needed for one of my discs. Try them- they might surprise you.....
The specific parts I need are VR 2627 bearing spool, and VR 2702 shell in lower bearing cap. Thanks, Ellis
If you can not find the parts anywhere; Is there any chance you could simply build up the worn parts with some weld and freehand reshape with a handheld grinder? (Alternately, you might even be able to reshape to slightly different shape that is more commonly available for parts instead original). Heck one of your posts the other day mentioned a lathe so the possibilities are endless with a lathe.
