Got an old 1032 bale wagon that sat for years, completely drained of hyd fluid, and have been going through it. I tested the push-off arms, and one (right arm facing fwd) extends first, and then, as soon as it is fully extended, the left arm will extend. The same is true for retraction- the right one will retract fully before the left one begins to retract.
Obviously, this will not be helpful when unloading hay. I have checked the interlocks and everything seems to be working properly. Maybe all I have to do is actuate the push-offs a few times to get them to start working together? (Air in the system)Or is there some other problem?
Thanks.
Thanks.
