winter maintenance time
wellmax99
be sure to drain the water out of those air compressor tanks!!!!!!!!!!!!
check antifreeze coolant levels in all the old motors stored around that are not used that much during the winter.
Also check all ground cable connections. Cold weather makes the contact less in many cases, so a good clean connection is better.
Any Diesel that I own that runs in winter gets a fuel filter between Halloween & Thanksgiving regardless of annual hours of use.
Bring equipment home. If you wait until next spring to go get it, it can be hard to remember where you left it, and can take awhile to find it. As soon as I get over this cold I am going to go get my Tedder. I happened to drive by the place yesterday and saw it.
