This message is a reply to an archived post by hayfarmer on May 30, 2015 at 17:30:32.
The original subject was "Re: charlynn 960 control valve".
I have a #35 hydraulic dump loader on my 1959 430 and am looking to fix the Char-Lynn 960 control valve on it. The bore of one of the valves was corroded so I tried to clean it up and replaced the seals a few years ago but now it leaks like crazy again. I think am going to need to replace it. Hayfarmer mentioned Surplus hydraulics as a source. Can someone help with contact info or link for Surplus hydraulics or any other place I can get a replacement and some more detail on what valves can be used? I don't have much experience working on tractor hydraulics, so details are appreciated.
In the archived post by hay farmer in response to a question similar to mine from co94bra, hayfarmer said "try Surplus Hydraulics. what tractor is the #35 on? that would determine if open center. I have a 2 spool valve from Surplus hydraulics on my 35 loader with hydraulic dump. works great and was resaonably priced. Depending upon how loader is plumbed you may need the power beyond plug."
