Dump cylinders?
Blue29
New User
Hi would anybody know where to find some replacement dump cylinders for a MF 100 or 101? My cylinders are junk and need "new" ones
Pretty easy to find them just measure how long they are when closed and then when open all the way then go to a place like surplus center
Hyd parts
The dump cylinders are what move the bucket forward and
backward. Angle iron your reply didn't come through.
So it is what is normally called tilt cylinders on a loader and they usually have special ends, not something you can get off the shelf.
I ordered a set from Surplus Center and had to modify the threaded end by drilling a 5/8 hole. I had trouble holding the rod straight for drilling and had to drill with a Bridgeport.
