Ford 903 post hole digger
TimPa
need to replace the oil seals on the output shaft (2.5" shaft dia). pulled the first seal, and there appears to be a second seal seal on there. messicks only lists the deeper seal, the top seal not available.
has anyone ever cross referenced these 2, replaced them, can share any knowledge about them?
101737 oil seal (1/4") top
7001575 oil seal (15/32") next lower
Thanks in advance
(quoted from post at 19:34:39 10/29/15) need to replace the oil seals on the output shaft (2.5" shaft dia). pulled the first seal, and there appears to be a second seal seal on there. messicks only lists the deeper seal, the top seal not available.
Thanks in advance
Have you tried to cross the numbers???? I done my 903 a couple years back and it took standard seal from the local supply house
can you recommend a good cross ref site? when i did a search new holland didn't come up but i'll check thanks kevin
