ISO fleetline cultivator parts
ShepFL
Anyone got a lead on fleetline pipe cultivator clamps or 1/2 circle brackets? Looking for the rigid pieces that keep the pipe from from floating side to side in the frame. Open for any other parts as well i.e. fertilizer boxes :)
shepfla @ gmail
I made some of those side to side 'stops' once for a similar thing. Just found a chunk of pipe the next size bigger. Cut approx
1" long. Drilled a hole and welded a 1/2" nut on for a set screw. Worked just fine.Split it in half wand weld it back together
if you dont want to completly dismantle the cultivator.
