wi red dairy man
Was baling up the last of my corn stalks here the other day and all at once my pickup quit. First thing I did was back up and make sure it wasn't hung up still nothing. Jump shear pin is intact turn back on only one chain is running the the one that drives pick up is super tight and the slip clutch on the side is slipping. Everything else is running plunger thrower ect. I cleaned out the entire pickup area and I can't find any obstructions. What would make it lock up this tight can't even wiggle the pick up teeth it's rock solid. Maybe a bearing?anyone ever have a pick up off baler and torn down before? Thank you Josh
