I think I've got everything freed up and oiled on my 14t baler it had been setting in a barn for almost 30 years.I timed the feeder teeth so its 17 1/4 inches from the left edge of the feeder support. The needles measures 2 inches from the plunger head face when the knotter is tripped and the needle tips are flush with the top edge of the bale case bottom grove flanges on the compression stroke.I am having trouble figuring out the plunger head safety stop check. The book says trip the knotters and turn flywheel by hand until needles retract toward the home position and safety stop is flush with bottom of bale case.Then the plunger head on compression stroke should be within 2 3/4 to 3 3/4 from safety stop.
Can anyone explain this last step I'm just not getting it.
Thanks for the all your advice Joe
