Drive Shaft
Ron7000
I have a Big Bee brush hog. I can lube the drive shaft universal joint at the spline end but how do you get the plastic cover apart to lube the one next to the gear box?
Most shafts like that I have found had a hole in them you line up to get to the zirk to grease them
Unhook from the tractor and swing it to the side to find the zerk and figure out how to access it. You also need to find the hole to grease the telescope joint. You'll have to turn the safety sleeve to find the zerk.
On my howse brand cutter, the PTO shaft cover had small pop out plug in the plastic safety shied.
Just pop the cover off, grease the joint, then replace the piece of the cover you popped out. Worked good for years, but finally broke off.
