One of the belts broke on my Hesston 1091 haybine. The other belt is twisted, so I may as well replace both. But how the heck do I get the belts over that lower pulley? Obviously I needed to remove the shaft from the top pulley (the one that goes to the PTO). That was easy. But getting the belts over the bottom pulley looks impossible. I did remove the 2 bolts that attach the part connected to the sickle blades (looks like a tie rod end). But there is not enough space under it to lower that piece, especially when it's still attached to the sickle bar. Do I need to remove all the bolts going to the sickle bar too? -OR- is there a way to remove that whole "wobbler" assembly? I did remove the cotter pin at the top of the wobbler, but I cant slide it forward. I spent over 4 hours and still have no clue how to get that belt on.
~Frustrated~
--- HELP PLEASE ---
(Photos would be helpful)
Thanks
~Frustrated~
--- HELP PLEASE ---
Thanks
