Hello,
I have a Mott / Alamo 72 flail mower ( I believe ).
I think it is the old style cutter bar as the bearing housing has 3 bolts.
I have a vibration issue, and after looking have found that the bearing on the pulley side is bad and or the housing is bad.
You can see where something has cracked and is allowing the cutter bar to move around.
Can someone tell me how to fix this?
Some of the questions I have are:
How do I remove the cutter bar?
How do I remove the bearings?
Are they pressed on?
Would you also go ahead and replace the non pulley side?
Would you replace the housing?
How do I tell the difference between old and new style when ordering the parts?
How heavy is the cutter bar (do I need help with it) ?
Also, I have a new belt on it. after a few hours of use you can see wear on the back of the belt. The idler pulley has some pitted spots on it. Is this causing the wear on the belt?
Thanks for any help!
upnorthwi
upnorthwi
