Re: JD 336 wire baler tying issue
naylorbros
09-28-2015 13:40:42
My guess is that you should look and the twister shaft and hook. A groove will also wear on the twister shaft and the shaft and hook will sometimes catch the wire. It sounds like this is what is happening when you say "the knot on the bale looks like a double knot of wire." Another thing that can cause the double knot is the twister shaft could be a little out of time. The instruction book should tell you how to check and set the timing of the twister shafts so the hook faces the correct direction when it is done twisting. Twister shaft part # AE11324 about $89. hook part # E32458 about $84
Thanks
Ken
