Dunham cultipacker end bearing
I have a "newer style" Dunham cultipacker with a ball bearing at both outside ends I need to replace one-- shaft size is 1 3/4" and hole spacing is 3 1/2" held on by locking collars and had 10 ball bearings held with a plastic cage.
Anyone know where to find what I am looking for????
Thanks Rex
If everything else fails....I would take my failed bearing to almost any bearing supply house and they would be able to help you out. It will probably be expensive and possibly a special order. One has to believe that the manufacturer (Dunham) did not have a special made for them. Sometimes McMaster Carr will have the bearing you are looking for. Good luck!
