I have been having many troubles with a Minnesota No.7 (I think) mower. The trouble is in the pitman connection to the sickle. The pitman stick connects to the sickle with two cast iron pieces that grab a ball on the end of the sickle.
The mower had a long life before I got it and the pitman stick was broken at that time. Now it is breaking the ends out of the clamps that grab the ball on the end of the sickle. The original design had a fork and spring arrangement that looks like it was supposed to adjust the clamping pressure on the ball as things wore.
All of those types of clamps are used up. Could be a reason for that. There is an older style, part numbers M53 and M54 that will work, but the clamping force is adjusted with a draw bolt.
My question is How much slack should there be in the clamp ? Barely perceptible, or enough that it can move 1/32", or...
Thanks
Greg
Thanks
Greg
