New Idea cutditioner revisited.
Harryaroo
The belt available at shoup is just for the 279. The only belts I have been able to find locally started burning up pretty quick. Anyone else have a source of the right belt for the 272?
Something I ran into on mine that might help you out on burning up a belt. Check the alignment on the sheaves. Use a straight edge or a couple of framing squares. I had to loosen the gearbox bolts to get the sheaves parallel.
V-Belt supply part number is B67/03. IIRC they were less than $40. Another thing we did was to clean up any rust and scale on the rotor sheave with a wire wheel. So far this belt has held up well.
Thanks-- I got that belt from vbelt supply and save $100. Great-- Did you find that it was difficult to put on?
