C-36-A FH Disk Parts Search
I'd like to restore my C-36-A FH disk but having a few problems locating parts, specifically bearing parts, even more specifically the spool bearings. For the C-36-A that PN is PA4133. The FCI-2 Parts Catalog also lists parts for the C-38 Disk Harrow and C-42-B Offset Disk Harrow. To my eye it looks like the spool bearings should be the same as each of these disks should all possess 7/8" arbor bolts (assumption here).
The PN's are -
•For the C-36-A spool bearing - PA4133
•For the C-38 spool bearing - PD3118
•For the C-42-B spool bearing - HWP73
So my question is this. Does anyone know if these spool bearings are interchangeable and then should I not be limiting my search just for PN PA4133? I do realize that although appearing in the parts catalog to be similar, differences could exist in spool bearing lengths if the disk-to-disk distances vary between the models.
Thanks in advance to all for comments/words of wisdom.
Kevin, my email is open (I think I did it right). If you send me an email I can fill you in on what I'm looking for.
Thanks for replying,
Bill
