owatana swather
dmiller
What are these like I believe it is a 235 based on some research. 13 ft. sickle rubber on rubber conditioners, hydraswing.
Parts still available. Would it be a step up from a 1091 Hesston or not? Would be 45% wider but that doesn't necessarily mean more hay cutting if I'm broke down more and can't find parts.
parts are non existent except for guards and sections bearings are generic and belts outside of that you will be on your own
Lots of em parked around here because you just can't get parts not to bad of a machine but uo until a few years ago you couldn't even gaurds for em use to have to take a new Holland gaurd and shim it with washers to make it work
