hoosierhog
Ok so I need some help deciding what to do.
I bought both of these discs from a good friend and neighbor for a 100$ each. They are both oliver discs one has a tag and says model 242, it has the tandem wheels where the other looks identical but has single wheels. Am it right to assume that they are both model 242? also my original plan was to move all the good parts to one disc to use then scrap the other but now I'm rethinking that idea and was wondering what would you guys do? I am going to pull 1 or the other with my farmall 656.
the tandem wheel disc has 10 blades per gang and measures close to 12ft 6in it has several broken blades and a bent axel on one rear gang. the back blades are 17ish inches and the front are down to 15ish.
it needs at least one spacer and probably all knew bearings. and most the springs to make adjustments are rusted and broke.
the other has single wheels NO paint left and has 9 blades per gang and is closer to 11ft 6in . the front blades where replace a few years before the former owner retired so they are 17+ inches across and the back are about the same but not exactly. it does have one broke blade on the back but all the springs and adjustments seem to work. it will needs hubs wheels and tires. but really it is in much better shape of the 2.
The slightly smaller one is in much better condition so will need less work to get in the field but I really like the bigger one with the tandem wheels. I don't really want to scrap either. which disc would you guys keep? and is it worth it fix them both up. (funds are limited so it would be a LONG term project to fix both).
thank you.
