Dearborn 10-1 3-bottom plow
Did a search on here, and found quite a lot of info on Dearborn 10-1 plows, but it looks like the 10-1 is a 2- bottom plow - the one I have is tagged as a 10-1, but it's a 3-bottom unit - anything unusual about it?
Thanks!
Did a little research in the New Holland parts catalog, and it would seem that there was a conversion kit to add the 3rd bottom. Parts listed for 12", 14" & 16" bottoms. Farmer, I knew back in the day, had one with 3-14" bottoms that he pulled with a 971.
HTH, Dave
Third beam conversion. It was available at the time. You also had to move your second bottom with longer landslide and
tail wheel to outside
Kirk
Here's a ferguson plow that needs work with the third beam conversion. These three bottoms plows are easy to sell cause
you can always turn them back into a two bottom to pull with the old N or ferguson tractor and have an extra bottom for
parts or for use as a three bottom for a larger tractor.
Kirk
CL link
Here's what would have came with conversion. Bottom was separate.
Kirk
