New Holland 450 sickle bar mower
old
So have this one I am working on. The wobble sort of thing that drives the bar has a part that is sort of a triangle with a number of bolts it pivots on. One of the bolt holes is way bigger then it should be. Is this something I might be able to find at a NH dealer. Got home way to late to check
The low s/n's are getting harder to find parts.
Try here http://www.lancasterfarming.com/www/Joes-Machinery-Retail-2015.pdf
I could if I knew where the hole should have been but is it egged out so bad not able to tell where it should be
If its the side plate you better sit down before they tell you the price.My idea would be to take the plate off buy one from the NH dealer and then take both to a machine shop and they could use the new one as a pattern to repair yours and then return the plate to the NH dealer.I've done this with a couple things and the dealer knows what I'm doing helps that the parts guy is a relative and the owner and myself share a not too common last name and he's big into family tree type stuff.
Call the Agco/NH dealer I have been dealing with for 35 years today to check on the cost of the parts. $35 per each which is not all that bad for those parts or at least I do not think so and he has them on hand
