John Deere running gear
Suffolk1
I've got a set of John Deere running gear and I'm trying to find out the capacity rating. From the metal tag on the frame I found the following information: Type W1065 and Serial No. 136030W1 (best as I can make out the numbers). The wheels are 6-bolt hubs and 11L-15 tires. Where can I look to find information on the capacity rating?
Same thing with the old standby JD 953 gear, they are a 4 ton but it seems like everybody thinks they are 7 to 10 ton gears.
