917 flail mower
i have a 74" ford 917 flail mower i picked up for $250.00, it appears when the blades and blade links get warn down they can actually hit the underside of the mower, the blades this mower has are the two separate blades that hang from the link, question #1, can you purchase the entire set of blades and links for the 74" mower with out purchasing the hangers, question #2 is there a shorter blade or link that would still work in the 917 and question #3, where would you recommend purchasing an entire set?
thanks dave
gowen mi
My 917 is 6'6" wide, offset to the rt..and has the original triangle knives on it and they have never rubbed...
Takes some HP in really heavy and large grass..Ford sells them.
I suggest replacing the mounting bolts each time they are removed, just to keep from loosing a knife..
I have a set of the 2-piece knives and they are a little shorter than the tri-angle knives..
Ron..
