Hay hay hay
An odd one, and first time for me. The pin that holds the twine disc gear on the shaft sheared.
This is the gear that meshes with the worm gear. No mention of the pin in the manual.
Never had this happen before and I had baled about 100 bales today when it happened.
It is relatively easy to replace if I can find the part.
Does anyone know the size of this pin? and, Is it a special material?
Do I need to check for other failure causes before I replace the pin and go back to baling?
NH 276 twine baler.
Thanks
NH 276 twine baler.
Thanks
