Need NH Hayliner 310 pickup cam bearings
I've been trying to find the bearings on the New Holland parts site. But I can't make out from the parts breakdown what much of anything is in the breakdown.
There are 3 of these bearings on the right side of the baler pickup. The round drum (not sure what it is called ) that the bearings ride on is wore and grooved from chewed up bearings riding on it, can anyone tell me availability of the bearings and what the drum is called and it's availability.
I can tell you for sure that the rest of your baler is not far behind the cam bearings and cam track. BTDT! Do yourself a favor
and sell/trade/junk it before you get truckloads of money into it,only to have something else fail when you need it most.I had a
283 that lost a cam bearing and wiped out the track.While you have that pickup apart,you shouldreplace EVERY bearing in it.Dont
ask how I know this....
parts key 35 Cam is 86837300 for standard PU $236.34 from Messicks
Parts key 43 shows 4 brgs not 3.
Thanks for explaining the parts diagram, now I see and can make out what the cam bearing is in the diagram and the place where it goes.
I'm supposing that if the cam got messed up by the blown bearings and has grooves in it now, that it should be replaced. I'll have to look again to see if I missed a bearing when I was removing them. I thought I only found 3, but clearly the diagram shows 4.
Also, my attempts at finding a service or shop manual didn't turn up anything. Is there an online store that has the shop service manual?
Thanks again for the info!
I found the 4th bearing, I will try to upload a picture of the cam to show wear from bad bearing's.
(quoted from post at 10:49:59 08/01/15) Thanks again, from your part # and descriptions I was able to get the parts @ $20 each at the local New Holland dealer.
ake sure you are also looking at the right diagrams. Reason I say this is I've seen 310s with both the super sweep and standard pickups. Stuff like bearings might be the same but the tracks and such might be different. Just saying, make sure.
