Can you help me on my JD 336 wire tie? I have two fingers on what I believe are on the bottom of the gripper and shear assy that each one looks exactly like a comma. In the round part of the "comma" there is a hole for a screw to hold them on. I believe what they do is both spin around and catch each wire and help with the twist or the shearing of the wire, not sure.
On the JD Parts Site, under the gripper and shear it looks like the parts would be the item #7 "blade", but that picture does not look like what I have, plus it shows a total of 4 screws and I would only have 2, one for each one. Unfortunately I don't know what the pieces are called, but there is one on the bottom of each one of the vertical shafts, with a screw going up into it from the bottom. They would each be setting just above the bale.
I need to order new ones, but between the parts guy and myself we don't know what for sure to order. Would you have any idea what I am referring to? I know the "blade" that is in the parts book is not correct and I hate to order it just to see it and tell them it is wrong. Thanks for any help - Bob
