Joes Massey
New User
I've got a old Dearborn 2 bottom disc plow that I need to locate 1 or 2 disc for.They are 22 inch dia with 5 screw holes and the center hole. I loaned it to a friend of mine and one of the disk got messed up pretty good.Any help would be great.
As a last resort, you might buy a 22" disc blade.
Place your good blade off your plow, over the new disc blades, center your blade on the new blade,
Take a torch and blow out matching attachment holes.
I have used this process to replace the rear flat disc guide blade on a number of Ferguson disc plows.
Hopefully you will find the correct disc plow blade.
(quoted from post at 18:38:58 07/22/15) I've got a old Dearborn 2 bottom disc plow that I need to locate 1 or 2 disc for.They are 22 inch dia with 5 screw holes and the center hole. I loaned it to a friend of mine and one of the disk got messed up pretty good.Any help would be great.
The disc are 26" when they are new. Go to an Agco dealer and order Massey Ferguson 660126M1. That is the disc for their #64 disc plow. Same bolt pattern as the Dearborn. At Jackssmallengine.com the are $92.86 but that is for the 1/4" thick disc. Temco used to offer them but they were a thinner 3/16" thick disc and costs the same as the Agco disc.
looks like Jason put you on the right track.
much easier fix than my method would be.
here is a picture of my old MF 64 disc plow rolling a little dirt.
good plow,
Got my old disk plow fixed for the moment,had an old disk I cut a section out of and cut a section out of the damaged disk and welded new piece in it's place.Good to go for now.Gonna get me some of those thick one's before spring.Thanks everyone.
