Vermeer 504 pickup info needed
There are is a 4-5-6 bar pickup for the F G H vemeer balers all will interchange do not use the track from a early F baler. They had problems with teeth breakage. Later ones had rubber mount teeth. Track and rollers on left side. They mount off of bearings on shaft of bottom roller. Pickup plate is slotted to clear shaft. Bearings and drive pulley must be pulled. First set each side on 6x6 blocks then disconnect lift handle and springs and belt fill in pieces. Then remove bearings and pulley. Entire unit can then be slid forward be careful it will try to get funky and fall every which way. Parts will interchange. Replace track bearings while you are there 1 per bar. Can't
