Electric Wheel Co.
PiedmontVa
New User
Need 16 inch wheel / solid center hub/ 5 bolt for Electric Wheel Co. wagon. Photo attached. Bolt spacing is on a 5 3/4 inch circle.
Are you missing a wheel or is one of your wheels rusted on the rim? I have four wheels like that on a running gear under a Little Giant gravity box. All four were rusted when I bought the box and I couldn't find replacements. I ended up
getting 16 inch rims from a salvage yard, taking out the centers, and then welding my centers into the different rims. It's worked fine so far.
You are quite resourceful and capable!
In my case the wheel is missing; this running gear came out of an auction. So I will keep looking for that wheel.
Thank you.
I have just what you need - the wheel in the photo. It's a bit older, but still in good serviceable condition. No
rust around the valve stem hole. A couple small rust-through spots can be easily repaired. They are not located on
the bead. See photos attached. Located in Cheyenne, WY - 82001. Email if interested. Thanks.
<a href="http://s72.photobucket.com/user/Rick-WY/media/IMG_0201.jpg.html" target="_blank">
</a>
<a href="http://s72.photobucket.com/user/Rick-WY/media/IMG_0200.jpg.html" target="_blank">
</a>
<a href="http://s72.photobucket.com/user/Rick-WY/media/IMG_0202.jpg.html" target="_blank">
</a>
<a href="http://s72.photobucket.com/user/Rick-WY/media/IMG_0203.jpg.html" target="_blank">
</a>
Just to be clear, the photo you posted is my wheel. I assume you copied it from the
archives? I will list the wheel is the Parts Ads. Thanks.
Get it while you can so you have a spare tire and wheel ready to use if one goes out and they will at the most inopertune time like on road with load. They have spent over an hour welding up a wheel for me the blew while setting on the road with a load of beans. And mine was the 6 lug version of yours that is just about as hard to find.
We used th have a pair of the 6 bolt style running gears, one for wrecked and i found another rim at the scrap yard. Now we've got 5 extra 6 bolt rims like that.
Donovan from Wisconsin
