gary in neb.
looking at a white 5100 4 rw planter with a 5 rw splitter attached. couple questions is someone can help me. the monitor is only 4 rw. do the splitters not usually run on a monitor? the planter has disc openers on the front four and the two outside splitter units. the middle splitter unit has a little cultivator shovel like thing the the other two splitters have nothing.
also, it's missing the connecting shaft that runs the splitter. looking in the hole where it's suppose to be, the bearing bracket on the front unit don't line up with the main frame on the splitter unit. probably not a big deal to get to work.
anyone run a splitter like this? thoughts good or bad? will replace a 5100 4 rw with no splitter.
Gary
Gary
