Tx Jim
- Location
- Coyote Flats, Texas
This is a heads-up posting:
The single acting lift cylinder on my newly purchased,barely used Krone AM283S disc cutter wouldn't retract all the way to raise cutterbar 90 degrees. I disconnect cylinder from cutterbar & it still wouldn't fully retract. I disassembled cylinder to find the breather plugged plus hyd oil on the backside of piston. I cleaned out the oil & breather,installed new piston seals so now cutterbar rises 90 degrees.
