diamondebulls
New User
I've got a 273 hayliner small square baler and my clutch plate was wore out on the overrunning clutch, so I replaced the clutch plate and the pins and springs. Had pins stuck in the shaft and had a tough time getting them out, ended up having to drill in the pins to get them pulled out. Got it all put back together and seemed like it was going to work fine and started to bale with it yesterday and it started slipping immediately again so I tightened the clutch springs up a little and started again and the clutch plate broke with not even 2 bales baled. This overrunning clutch has been a headache ever since I started having issues with it. The shaft with the pins in it had washers in the bolt holding it on, just curious if I was supposed to take those out when putting the new plate on to tighten it up or if that mattered, any suggestions would be greatly appreciated thank you.
