Plowboy1
Can someone tell me if the remotes on a JD 2750 are special jd couplers or standard? We are new to this tractor and are having trouble with these leaking/ not coupling. Thanks.
If it"s like my 50 series (4450), with the factory remotes, it"s an ISO coupler....hose end looks similar to a Pioneer, but longer shank, and won"t accept standard Pioneer. Nor does it accept the tapered JD coupler of the 20, 30, 40 series tractors. You can get adapters to go from Pioneer to ISO, which is the standard of the industry.
As stated male tips are ISO. For oil leak control it's possible seals(parts key 19 & 20) need replacing which can be accomplishing with coupler attached to tractor
i guess i didnt know there was a difference . can you explain what is the difference between pioneer and iso . is iso what all the newer tractors take
