coating round baler flat belts?
mmidlam
the floor belt rubber is worn though and now are fussy. I am thinking I could paint them with a rubber coating and get a little extra use. I might try rubber roof coating. Have any of you tried this? Is there a better rubber coating to try?
If it is wore that thin, it may break if you get into some tough conditions.
The coating will not help with strength.
I would replace it if I baled much hay cause they always seem to break when you got 20 acres down with a storm cloud coming. :)
Gary
I really doubt that roof coating would do more than make a mess. Take your knife and try to cut into cured roof coating. Do the same with your baler belt. Notice the difference?
