Any tricks to help me get this thing to work right would be great.the hyds are strong,swapped hyd outlets around,tried thicker plastic
twine 9000 or 7200 no change like to use 20000. You can shave with the knife all the linkages look new,the string is routed like it should be
and the spring clips look clean.the twine just slides thru, I shimmed up the cut bar and loaded up the pressure springs right by the cut
mechanism to no avail I must be missing the obvious.nothing is bent I finally just used the front single pipe and cut by hand.help my knees
please
thank you
please
thank you
