Vermeer 554 XL repair
NEKS
A bearing went out on a idler sprocket. The baler is a 554 XL wide mouth and the bearing is in behind the cylinder bracket that pulls the feeder up and down. The chain runs the small roller down front and the large drum roller. About ready to take the cutting torch and remove some of the bracket to get to the bearing or spend a half day removing parts to get to it. Maybe someone knows of a easer way to fix it.
