I have an old David Bradley side delivery rake
That I got thrown in when I bought my old Oliver 520 baler. The David Brafley is a 4 wheel trail dragger type of rake with the drive wheels in the front.
This type of rake makes for bad corners in the field when raking since the tail end will make for a overly wide rounding corner. Now maybe I have never learned how to properly drive the tractor to rake properly. This leaves a lot of hay in the field.
So on looking on craigslist I see a little newer type of rake that has only two wheels, has the tine setup that is more horizontal and can be either ground driven or run off pto. This type of rake seems like it would make for cleaner corners and cleaner raking in bumpy fields.
What is your experience with these rakes?
Which mfg built the most reliable rake in this style.
My budget is less than a thousand. I am only bale 9 to acres per year.
