IH 412 plow lift bracket
I'm looking for a lift bracket for an IH 412 mechanical lift plow. Its part number is 461688R11. It mounts to the upper left fast hitch arm on a 560 tractor with two bolts and then has a hole at the other end for a chain to fasten to. I would even like a good picture with measurements if someone had one of these brackets and could get these for me. I could probably make one then. Any help is appreciated. Thanks in advance.
Some of the 412s had a hydraulic cylinder that raised the rear of the plow and then some 412s was mechanical lift. It has a pipe that comes from the wheel lift linkage at the rear of the plow to another linkage with two arms the front of the plow. One of these arms has a chain attached to it. The bracket that I need mounts to the upper left lift arm of the fast hitch on the 560. The chain mounts to this bracket.
Gotcha. Ok well mine is a hydraulic lift. I see no where on mine for the part you are describing. Sorry I could not be of more assistance.
Matt
(quoted from post at 12:41:38 05/29/15) Some of the 412s had a hydraulic cylinder that raised the rear of the plow and then some 412s was mechanical lift. It has a pipe that comes from the wheel lift linkage at the rear of the plow to another linkage with two arms the front of the plow. One of these arms has a chain attached to it. The bracket that I need mounts to the upper left lift arm of the fast hitch on the 560. The chain mounts to this bracket.
never seen a 412 plow like this. My old 412 had hydraulics.
If you go to the case IH parts lookup and type in 412, then go to the transport lift linkage towards the bottom of the list, it will show all the linkage that I'm talking about.
