tomstractorsandtoys
I bought a Deere 920 moco with rolls and am having trouble with the header tilt. I have the skid shoes in the middle set of holes and the top turnbuckle adjusted to give the cutting height I want about 3 inches. I like to leave some stubble for the hay to lay on so it dries a little better and is easier to rake. My problem is when I raise the machine at field ends the cutter bar tilts forward and shaves the ground before it raises up. It moves forward several inches before raising. My turnbuckle was wore so it was replaced with a new.All the pivot pins take grease well but are showing some wear. I have all new pins and bushings ordered for the lift assembly but will not get them on for first crop. Any ides what else to adjust? On the NH 411 that I had the cutterbar tilted back before it raised up. I have the header float springs adjusted so it floats well,could I maybe have them to tight(if to tight it would affect cutterbar height which it does not seem to).I also have some trouble with dragging up at the end of the cutterbar as well. If I can't get this thing any better it will be traded on a NH 1411 or 1409 which never drag up. Thanks for any ideas Tom
