NH 156 Problems
Hi, I have a 156 Tedder that when i went to use it this weekend, i had the drive shaft come off of the pto while transporting it to my barn to grease it up to use. When i got everythign untangled and hooked up properly( the spring loaded lock wasnt engaging the whole way)it seemed that when i powered it up the tines would clash occasionally. Im not sure what could have happened. there seemed to be a bit of slop from one rotor to the other....maybe an inch or two. HAs anyone ever seen the "timing" go off like this? What should i check first? The operators manual doesnt really show much in the way of timing it so the rotors are spaced evenly when they travel thru the center. Thanks, Neal
