Old Ferguson plow
bcny
I have an old Ferguson 2 bottom plow, I think it was purchased new along with a TO20 way back.
I want to know if it is the 2-12 model. I measure 12" from share to share. Does that id it as the 2-12?
I think they made a 2-14 and 2-16 also.
Thank you.
(quoted from post at 05:07:16 05/26/15) I have an old Ferguson 2 bottom plow, I think it was purchased new along with a TO20 way back.
Thank you.
Measure across the beams center to center. That measurement will tell you if it's 12", 14", or 16".
I have an AO2-14 and love it. Most parts are NLA so don't break anything...
It measures 12".
The coulters are missing.
The furrow wheel broke off its spindle.
Otherwise looks pretty good.
My tractor has a 14.9-28 rear tire, is that a little too wide
for this plow?
(quoted from post at 07:28:17 05/26/15) It measures 12".
for this plow?
My coulters are missing as well; sucks in fresh sod but otherwise ok. They can be found used.
The furrow wheel is a must...or extended landside on the rear bottom. Else it will want to keep tracking out of the furrow.
14.9 should be ok. I would just crowd the outside of the furrow with the front tire. You will have you try it and see. I run 11.2 and 12.4 without issue running down the middle. Smaller would help your rear tire fall into the previous furrow and track better.
