Fast Hitch 4 row cultivator Model #
Farmall43
I am attempting to find a model number for my 4 row fast hitch cultivator. The paint is in bad shape and none of the markings are readable. I appreciate the help. I would like to get an owners manual for it.
Thanks All!
Matt
I think I have several, would just have to dig them out. If I have would just like the postage to mail it.
I will get pics of it while I am at the farm later today. I did not realize there were2 different 4 row models. Thanks.
There are also 463 and 63 4 row cultivators. The difference is there are more "gangs" on the 463 and 63's. There are 2 gangs between each row on the 463 and 63's and only one gang between the rows on the 453 and 53's. The difference between the 453, 463's and the 53, and 63's are they dropped the "4" when they came out with the 6 row cultivators. I have a 453, 53, and a 63 cultivators all 4 row.
Ok there are 2 gangs between rows. If it makes a difference it is a McCormick International. If I remember right that makes it older. So I am guessing that it is a model 63. Main question is when setting for 30" rows where do you put the stabilizer disk? there is not enough room to put it between gangs on either side and because of the round tube the tool bar mounts to you cannot put it in the center. Also. If I fab a new bracket so I canmount it in the center will it still work like it is supposed to?
Thanks All!
Matt
Your email was open, just wanted to make sure you recieved it. The book covers setting for 28" rows as well as wide rows but not 30" but from 28" to 30" should be easy to figure. It covers 3 different shanks and it also covers the ROLLING GUIDE FIN, not coulter that is not a correct term. I may have other versions as well did not look that far.
