freeman 4000
cobrajp1
New User
Hi I have a freeman 4000 loader that I want to put on my ford 801. I'm trying to find info on it but have had very little luck.
Does anyone have pics of how this loader is set up?? I don't have the hyd pump, tank, or controls but I do have that stuff from another loader I scraped that was no good. any help would be good thanks
Joel
I have one on a 62' 4000 which is the same as your 801. The frame of the loader is your tank. The pump mounts on the front coupled to your crank pully. There should be a plate on the front that mounts to the front bolster of the front axle. The back supports mount under the rear axle with your fender mount bolts. If you don't have power steering it will be a bear to steer. That loader is heavy.
Where are you located. I'm in Jersey. If you are close by you can come and look at how mine is mounted.
Hi thanks but I live in upstate NY by Batavia or I would come by and look at it ha. If you could send me some picks of the pump also tank and lever set up and picks overall would be great thanks
Joel
