beeper on round baler
I hooked my buzzer alarm up on my 650 new Holland baler. Hooked it straight to the battery and it won't beep or flash. Do you think it could be a sensor
<image src="http://forums.yesterdaystractors.com/photos/mvphoto20640.png"/>
Hooked the red wire to positive terminal and black wire to my negative post so it should have a good connection
It doesn't beep until your bale is full and the knotters are actuated and about to trip into the baler throat, then again when the twine arms re home.
If it's like the 630 control box it only buzzes when the bale is full.
Hook everything up, plug the baler in and find the switch on the bale indicator, you should be able to close the switch by hand and hear the buzzer go off.
I don't have autotie, but it only buzzes when bale full, at least on 630 all the buzzer/light is physically connected to is the bale full switch on the actual baler.
