JD 7000 Marker problem
LKnolls
New User
Can't get the markers to lower, either side. I have had a rodent issue in the past, removed the actuator and cleaned it up, but need help getting the marker arms to drop. Thanks in advance.
Hold your hydraulic lever in the up or down position rather than letting it go to float. Look for fluid leak from the frame. If there are no leaks your hoses are good and you have that mouse problem again. I made a special blowgun from a 6 foot length of brake line to clean that out.
First of all, how do you have the marker hose plumbed? Is it tapped off the remote cylinder, or do you have it running direct to the tractor? These questions will need to be answered to know how to respond. If the actuator has a mouse nest in it one marker will still generally fall. It just won't switch. Mike
